rides like a tractor
Old Apr 17, 2009 | 03:11 PM
ROBLU540's Avatar
Default rides like a tractor
I just recently replaced new front struts and rear shocks on my 850 platinum. with new spring seats. there were no bump stops were missing so put everything back together without them. But my car still rides like a tractor. I can feel every little bump at low speeds and at high freeway speeds it raddles my entire from compartment. What could be the problem. I used OEM Sach struts and rear shocks. I checked the bushings on the control arms and they seem to look okay but not an expert. any help appreciated.
Old Apr 17, 2009 | 10:50 PM
dan2286's Avatar
Do you have stock rims/tires? What is the air pressure in the tires at?
Old Apr 18, 2009 | 07:12 AM
Somthngfrce's Avatar
I wonder if now that you have new shocks, if the vibration is coming from the other parts of your suspension that are old. It's like the domino effect, your suspension is aging all at the same time, so if you replace the shocks,struts,etc.. Then the other bushings are old, and now that the shocks are stiff, the rest is now shaking! Just a theory to diagnose. Also check your tire balance to see if that is also the culprit.
Old Apr 18, 2009 | 05:36 PM
ROBLU540's Avatar
I bought Volan 17 inch rims that have 205/50/R17 Goodyear tires. The tires are a little stiffer than my last tires. One of the tires is shot, so was considering buying two new tires for the front. What tires do you guys suggest for 17 inch rims.
Old Apr 18, 2009 | 05:42 PM
ok, that's part of your issue. I Just put on Volans on my 850 and I imediately noticed more road vibrstion in my steering column and car. I went from a thicker tire to a 45 series. Since your side wall is smaller, it allows more vibration to come thru... That's just part of having a bigger wheel. I have Yokohama Avus 215/45/17's on my Volans.
Old Apr 19, 2009 | 09:10 AM
Psaboic's Avatar
Did you replace the spring seats and strut mounts when you did the suspension? They go bad quite frequently
Old Apr 19, 2009 | 06:59 PM
ROBLU540's Avatar
Yes, i bought new spring seats, oem not the cheap version from fgp groton.
daver80
Feb 28, 2012 09:33 PM
Typhoon
May 11, 2011 09:59 PM
EDisEPIC
Aug 29, 2010 08:46 PM
dooley
Aug 3, 2007 06:11 AM
motocopter
Oct 28, 2004 07:28 PM
