rims
Old Sep 20, 2005 | 04:54 PM
delichani's Avatar
Default rims
i want to know the bolt pattern of a 1993 850 GLT
Old Sep 20, 2005 | 09:28 PM
Default RE: rims
First we need to know if you have 4 or 5 lug.
Im not sure of either one but someone else here migth.
Old Sep 21, 2005 | 11:49 AM
robert213's Avatar
Default RE: rims
Five Lug...
Remove one of your factory wheels. On the back side, you will find all kinds of numbers cast into your wheels e.g. 6.5JX15 5x108x43
6.5x15 -- 6 1/2 inches wide and 15 inches in diameter
5x108 -- 5 bolts spaced 108 mm apart
43 -- 43 mm offset
Most aftermarket 5x108 wheels use 35 mm offfset, which is about right for Ford Taurus, but is too close to the outer fender for Volvo. Volvo front wheel bearings and hubs were designed to have the weight of the car distributed across 43 mm wheels -- regardless of 6.5, 7, or 7.5 inch width of wheel.
Compare a regular Volvo 6.5x15 wheel against a 7x17 wheel (e.g. Volan). Cast inside of both wheels is 5x108x43.
Old Sep 21, 2005 | 12:41 PM
robert213's Avatar
Default RE: rims
Discount Tire says... 4x108mm
http://www.discounttiredirect.com/di...vid=000618&bp=
Old Sep 21, 2005 | 09:58 PM
Default RE: rims
ORIGINAL: robert213
Five Lug...
43 -- 43 mm offset
1993 was a split year with 4 lug and 5 lug rims.
Dex2020
Feb 7, 2019 02:21 PM
KREID
Sep 26, 2005 12:49 AM
sbrownbw
Feb 15, 2005 09:46 PM
Steamroll9
Jan 25, 2005 08:37 PM
cauqazn
Nov 2, 2004 05:22 PM
