Rod knock?
Old Sep 2, 2013 | 11:12 PM
eriknorcal's Avatar
Default Rod knock?
Ok so last night after a decently hard signal pull, I noticed this noise. At first I thought it was coming from the top end, but then I took the second vid and it worse from underneath. I put in a quart of ATF and some seafoam to see if maybe it was just a collasped lifter or clogged oil port but after 15 minutes of driving it started to misfire and throw a code, and finally died right next to my house.. Won't start.
Rod knock? Or valve issue?
Old Sep 2, 2013 | 11:40 PM
boxpin's Avatar
Now that we have the second video it sounds like a rod knock or spun bearing. Sorry to hear man. I had to replace the engine in our green wagon with the same problem.
Here is a spun bearing
Old Sep 3, 2013 | 11:18 PM
eriknorcal's Avatar
Update:
Runs now. It was one of the positive wires coming off the battery, it was loose :l
But the knock is still there. I will be pulling the pan this weekend, or maybe just the whole darn thing
rdklxprs
Jul 21, 2015 09:46 AM
Aglowmobile
Nov 22, 2012 04:10 PM
andrewwhite149
Apr 22, 2012 01:33 PM
ruggles
Mar 3, 2010 04:19 PM
lizard
Sep 1, 2005 08:48 PM
