rook leak :(
Old Dec 17, 2009 | 02:59 PM
ruggles's Avatar
Default rook leak :(
The headliner on the passenger side gets soaked when it rains. It usually takes a day or two to saturate. I blew out the drain lines and they were fine and intact. Is there anywhere else the roof could have a leak that would cause this? The only thing I can think of is that the seal between the sunroof mechanism and the inner ceiling might have failed? Any ideas? I want to drive it off a cliff right now
Cheers
Old Dec 18, 2009 | 12:42 PM
ruggles's Avatar
no ideas?
Old Dec 18, 2009 | 01:41 PM
Bobec's Avatar
You might have to pull the headliner down around the edge of the sunroof opening so you can see the under side of the roof. then run water from a garden hose over the sunroof area to see, if and where it is dripping. If you see a sign of water entry it doesn't mean that is where the leak is, the water can travel as it enters. Try doing a localized area, like the front right corner, park the car on an incline down and to the right so the water runs in that direction and not back or to the left, give it some time. then move the car so it inclined up and to the right and run water over that section. Sometimes they are hard to locate.
Old Dec 19, 2009 | 07:50 AM
Tht usually means the seal on the glass is bad. The water runs around the seal then drips inside of the tub area of where the drains are. Both of my cars have the problem as well. But the leak is really minor so I have not fixed them yet.
Old Dec 20, 2009 | 09:48 PM
ruggles's Avatar
yeah thats what I was thinking it could be tech except that I sealed up the sunroof temporarily and its still leaking so wtf is that about? Anywhere else it could be coming from?
Old Dec 21, 2009 | 03:27 PM
ruggles's Avatar
where could it be leaking besides the sunroof!!!? Any other ideas?
Old Dec 21, 2009 | 10:04 PM
Did you pull the A-pillar panels and make sure the drain hose did not come off?
Where exactly did you seal?
Old Dec 22, 2009 | 11:51 AM
ruggles's Avatar
i checked the hoses and blew them out. I sealed it up temporarily with some awesome new 3m transparent 6X stronger outdoor duct tape and it is still totally sealed. this is what leads me to believe its coming from somewhere else. any ideas? This is driving me nuts.
Old Dec 22, 2009 | 06:59 PM
Did you seal just the glass or between the glass and the roof?
Old Dec 25, 2009 | 02:52 PM
Default Seal the sunroof...
I don't think it's possible to seal a leak with any kind of tape. The prep-work would have to be near perfect. You should try some kind of sealant. I fixed my 960 sunroof leak with black silicone sealant. Here is the link to that post: https://volvoforums.com/forum/showpo...1&postcount=19
Besides that, I have a 850 sunroof with a good seal on it if anyone needs it. I would sell it for $65 plus shipping.
Old Dec 27, 2009 | 10:16 AM
ruggles's Avatar
I didn't want to permanently seal it shut, I just wanted to see if it would slow it down which it didn't seem to do. That makes me think it could be coming from somewhere else. The truck is always wet too. It's full of condensation just the the roof.... I may seal between the glass and the seal to see what that does... It's really pissing me off as the car only has 169,000 KMS and it's falling apart
2008XC70
2001-2013 model year XC70
Dec 20, 2017 03:07 PM
ROBLU540
Feb 20, 2009 07:59 PM
1999S80T6
Dec 16, 2008 04:54 AM
