rpms drops on idle
Old Nov 14, 2011 | 04:54 PM
  #21
I'm not sure about that hose. If I had to guess I would say it leads to the power brake booster. I'd have to pull the air cleaner housing out to track it and that's something you can do too.
CHECKING FLUID LEVEL
1) Ensure vehicle is level. Apply parking brake and gear
selector lever to "P" position. Start and idle engine. Move gear
selector lever through all gears, while pausing 4-5 seconds for
engagement at each position.
2) Return gear selector lever to "P" position. Wait 2 minutes
and check fluid level with engine idling. Level should be between MIN
and MAX marks.
RECOMMENDED FLUID
FLUID SPECIFICATIONS
Application ATF Type
850 (AW50-42) ....................... Dexron IIE Or Mercon
940 (AW-70) .............................. Type "F" Or "G"
940 Turbo (AW-71) ........................ Type "F" Or "G"
960 ................................. Dexron IIE Or Mercon
FLUID CAPACITIES
TRANSAXLE REFILL CAPACITIES
Application Refill Qts. (L) Dry Fill Qts. (L)
850 (AW50-42) ............ N/A ............... 8.1 (7.6)
940 (AW-70) ........... 4.1 (3.9) ............ 7.8 (7.4)
940 Turbo (AW-71) ..... 4.1 (3.9) ............ 7.8 (7.4)
960 (AW-40) .......... 5.6L (5.2) ............ 8.2 (7.7)
Old Nov 14, 2011 | 05:18 PM
  #22
MattyXXL's Avatar
Originally Posted by slimflex2
thank you very much.do u know the name of that hose with the green clip?its hard to pull out.l want order new one but l dont know what its called
Just cut it and bring the cut piece to an auto parts store they can match it up.
I replaced mine with a piece of silicone hose
Kevin Golshani
1998-2000 model year V70
Jun 27, 2013 12:18 AM
Tricky850R
Oct 17, 2010 03:06 PM
wlbirch
Jun 14, 2010 07:24 AM
outdoor7or24
Sep 17, 2008 09:26 AM
