Surging Idle / RPMs 1995 855 turbo *fixed*
Old Aug 26, 2008 | 03:45 PM
outdoor7or24's Avatar
Default Surging Idle / RPMs 1995 855 turbo *fixed*
Hey, I am new to the forum, and I hope I can find some advice and also give some advice.
I have a 1995 855 turbo and it has random idle / rpm surges. Any idea what is doing this?
If I drive with cruise control on, I do not have to fight it. It is wierd, the car just randomly speeds up for 1 - 2 seconds and then goes back to normal.
Any ideas????
thanks!
Old Aug 26, 2008 | 07:22 PM
Default RE: Surging Idle / RPMs 1995 855 turbo
Try cleaning the throttle body and idle motor.
Old Aug 27, 2008 | 08:07 AM
Is the idle motor below the throttle body?
Also, is carb cleaner good enough to clean it out???
Old Aug 27, 2008 | 06:41 PM
Carb cleaneris fine. Also the idle motor is more less infront of the throttle body. It has 2 hoses going to it.
Old Sep 17, 2008 | 09:26 AM
Fixed,
Cleaned idle motor and throttle body. Throttle body was dirty on the back side, plenty of baked on crud. I also replaced thermostat and temperature sensor. I believe surging was due to faulty thermo sensor, as when I started car up after replacing just thermo sensor, motor quit surging. It runs smoother now after cleaning idle motor and throttle body.
dawagner93
Jul 11, 2015 05:04 PM
palebeachbum
Jan 7, 2011 11:26 AM
outdoor7or24
Sep 17, 2008 06:51 PM
whwood3
Oct 20, 2005 09:12 PM
