Is an s70 turbo compatible with that of a 95 850?
Old Nov 9, 2015 | 05:43 PM
Radfordalum's Avatar
Default Is an s70 turbo charger compatible with that of a 95 850 turbo charger?
The S70 turbo charger in question has the following part number 1275663
Old Nov 10, 2015 | 09:33 AM
that part points to the 16T - it has a different flange - straight vs angled which the 15G on your 95 uses. It would not be a direct bolt in, you'd have to swap out the down pipe and perhaps work the coolant lines (not sure on that effort).
Old Nov 10, 2015 | 10:20 AM
boxpin's Avatar
The 16T and the 15G are both Mitsubishi TD-04 turbos. You can take the 16T and install it into the 15G exhaust housing and it will be a perfect fit.
But, your car is tuned to run with the 15G. The 16T is a step up and will work fine but really you should consider a tune when changing turbos.
bretterson
Nov 5, 2010 09:09 AM
coltdunkley
Sep 2, 2008 06:15 PM
jeff201865
Jul 2, 2008 04:41 PM
dannydoo
Nov 24, 2006 10:28 AM
