serp belt pulley replacement (not tensioner)
Old Jun 23, 2005 | 03:59 AM
Ocotillo's Avatar
Default serp belt pulley replacement (not tensioner)
Need to replace the serp belt pulley (not the tensioner one). Just wondering if anyone has done this and what is the procedure? Is there a torque setting for the bolt that holds it on? Mines gotten quite noisy.
Thanks for any help.
Old Jun 23, 2005 | 11:29 AM
Default RE: serp belt pulley replacement (not tensioner)
Some of them had a cap you have to remove to get to the bolt.Some don't have the cap.
Make sure it isn't the timing belt Idler making the noise and not the serp. belt idler.
Old Jun 23, 2005 | 12:59 PM
Ocotillo's Avatar
THanks, I plan on replacing all the pulleys until the noise is gone. If it's not this one then I'll do the tensioners for the serp and timeing belts.
Thanks
Old Jun 23, 2005 | 01:05 PM
The easiest way to find out is to remove the serp. belt and start the car and see if the noise is still there.
KCSteel3
May 10, 2015 09:28 AM
jeffintampa
Apr 16, 2011 10:39 PM
akem21
May 9, 2010 11:44 AM
jzm.oside
Sep 21, 2009 08:29 PM
