Tensioner Pulley for Timing Belt
Old Dec 18, 2014 | 03:03 PM
KCSteel3's Avatar
Default Tensioner Pulley for Timing Belt
I had the timing belt replaced on our 2004 XC90 last fall, and the tech used a Contitech Timing Belt kit to do the work. Now we are being told that the tensioner pulley is broken, and that it needs to be replaced. I am trying to find out if the tensioner pulley is part of the Contitech kit, because, if so, we are going to discuss this work being covered under the mechanic's warranty. Any help on this would be greatly appreciated.
Old Dec 18, 2014 | 03:10 PM
ES6T's Avatar
What's the part number on the kit? Or where did he source the kit? If it didn't come with the kit, he should have bought it separately and replaced it anyway. If it failed, you are probably looking at more than just a new tensioner,
Old Dec 19, 2014 | 08:16 AM
KCSteel3's Avatar
I spoke with the mechanic again, and what he said is that this is the tensioner pulley for the serpentine belt, which is different from the timing belt work he did last year. Seems like this is a totally separate issue.
Old Dec 19, 2014 | 09:12 AM
ES6T's Avatar
Ah yes, that would not normally be replaced during replacement of the timing belt.
Old Dec 21, 2014 | 04:05 PM
tony1963's Avatar
It is probably not the belt tensioner but the idler wheel and bearing.
Old Dec 23, 2014 | 08:29 AM
cn90's Avatar
The idler bearing was used in 1983-1997 Volvo 850 and 1998 Volvo S/V70.
After that the idler was eliminated, the the serpentine belt tension was accomplished by a single mechanical tensioner that uses a Torx key to loosen.
Old Dec 23, 2014 | 09:51 AM
tony1963's Avatar
2004 VOLVO XC90 2.5L L5 Turbocharged : Belt Drive : Tensioner Pulley
Price
ÜRO PARTS Part # 30637141P
Belt Tensioner Pulley
Pulley only; w/ NTN bearing; sold by Volvo as Tensioner/Pulley Set
$14.68
Old May 10, 2015 | 09:28 AM
cn90's Avatar
My apology to @tony1963, IDLER pulley is still used in 2.5T.
So when you buy the TB kit, it includes:
- TB itself
- Tensioner Pulley (which is a combo of spring and pulley)
- Idler Pulley
Buy it from Volvo dealer, it is OEM and cheaper than aftermarket.
About $110 or so.
Sherry007
Feb 28, 2015 03:50 PM
guest01
Nov 5, 2011 10:11 PM
akem21
May 9, 2010 11:44 AM
jzm.oside
Sep 21, 2009 08:29 PM
Ocotillo
Jun 23, 2005 01:05 PM
