service light
Old Dec 28, 2004 | 11:21 AM
hordezla's Avatar
Default service light
hey guys,
I was wondering if anyone knows how to clear the service light on 95 850?
Any help would be appreciated.
Old Dec 29, 2004 | 02:31 AM
Default RE: service light
I believe 1995 was a split year.Do you have a connector under the hood attached the the engine control module box?If you do install the wire into A-7 and push the button the number of times needed then wait for it to flash and then push it again till you are done.It is either 4-1-5-1 or 5-1-4-1 I forget exactly which it is.If you dont' have the diag plug under the hood you will need a service light reset tool.
Old Dec 29, 2004 | 04:31 PM
hordezla's Avatar
Thanks for reply!
I've already done that and it doesnt help. I did 4-1-5-1, that is suppose to take care of it but it didnt...any other clues?
Old Dec 29, 2004 | 04:50 PM
There was a few year cars that had the reset button inside the speedometer assy.There is a rubber plug in the clear plastic remove it and push the button to reset.That is if you have the button.Other than that im not sure some times its just easier to do it than explain it.
Old Dec 30, 2004 | 04:53 PM
hordezla's Avatar
Yes, my car has the reset button inside the speedometer assembly, that took care of it. Thank you![sm=smiley20.gif]
Old Dec 30, 2004 | 05:43 PM
No problem there are very few cars with it in the speedo cluster.
tngreg
Sep 5, 2022 07:27 PM
rred
Jun 28, 2011 08:45 AM
kijjh123
Sep 15, 2008 11:50 AM
mstrplmber
Aug 28, 2008 03:34 PM
soulfulimpressions
Jul 31, 2008 07:07 PM
