service light, obd2, diagnostic module
Old Feb 6, 2006 | 12:30 PM
fbhb54's Avatar
Default service light, obd2, diagnostic module
First I would like to thank so many of you that have posted cures for the 850 turbo wagon I just purchased. The subject posted at this time is the service light. I have both the diagnostic module under the hood as well as the obd2 port in front of the shifter. I tried the 1-5-1 method with no luck. A mechanic friend tried with the same result. This may be a dumb question, but when the ignition is turned on but the car is not started, 2 idiot lights do not glow. these are the "check engine", and "abs". ? should they glow and then go out after
the car is started.
Since I am here, can anyone point me in the direction for after market 3' down pipes, exhaust etc for this 1995 turbo. Thanks
Old Feb 6, 2006 | 07:34 PM
reg's Avatar
reg
Default RE: service light, obd2, diagnostic module
I should think that the two lights in question should light up prior to the engine starting............I wonder if they have been circumvented? The air bag is a pretty nifty thing when you strike an immovable object! TECH can comment on the light situation. Your down pipe can be sourced from IPD (www.ipdusa.com).
Reg
p.s. bring a bag of $'s with you when ordering the down pipe.
Old Feb 11, 2006 | 04:32 PM
From under the hood put the wire in A7 and then it is 4-1-5-1 that should clear the light.
treborly
Aug 11, 2012 01:49 PM
costa993
Nov 3, 2008 02:35 PM
aristo
Jun 15, 2007 10:36 AM
revdevil
Feb 16, 2006 10:34 PM
fbhb54
Feb 8, 2006 07:21 PM
