Shifter
Old Jul 25, 2006 | 12:48 AM
cava's Avatar
Default Shifter
How can you change the shifter?, I have a 95 850 turbo station wagon and I would like to change the shifter, it's not in very bad shape, but if it's not too much trouble I would like to change it, thanks...
Old Jul 25, 2006 | 01:33 AM
Default RE: Shifter
Just the **** or the entire shifter?
Old Jul 25, 2006 | 07:26 AM
cava's Avatar
Default RE: Shifter
The ****..., it's an automatic transmission, thanks.
Old Jul 25, 2006 | 01:41 PM
rp850's Avatar
Default RE: Shifter
Pull the retaining ring down that's below the shift ****. You'll see two plastic tabs at the base of the shifter - one on the front and the other on the back. Push the tabs in simultaneously and pull up HARD with both hands. Try to get as much leverage as you can when you do this. It takes a considerable amount of force but that's the procedure.
Old Jul 25, 2006 | 10:19 PM
Default RE: Shifter
Not really any need to push the tabs at the bottom. Just grab the top and pull like He**.
Also an easy way to undo the clip in the boot is to turn it and pull down.
Old Jul 27, 2006 | 01:36 AM
rp850's Avatar
Default RE: Shifter
Good tip. Would've made it a lot easier without holding the tabs! Also, I wound up breaking the retaining ring when I removed it. It just snapped when I pulled it down and cost about $5 to replace. I guess I wasn't gentle enough with it...
Old Dec 16, 2007 | 08:53 PM
Black 850's Avatar
Default RE: Shifter
Is it the same procedure with a manual shifter?
David.
Old Dec 16, 2007 | 09:12 PM
yert315's Avatar
Default RE: Shifter
Either turn it like a screw or pull really hard.. I dont know how the volvo is, but they were attached both ways. If the base of it is square you probably have to pull.
Old Dec 17, 2007 | 01:44 AM
JPN's Avatar
JPN
Default RE: Shifter
ORIGINAL: rp850
I hate it when that happens, I think everyone has been in a similar situation. If our "gentle" isn't enough, maybe grandma could do it for us.
JPN
Old Dec 31, 2007 | 07:44 PM
templar_just's Avatar
Default RE: Shifter
I have an 850 turbo. Is it the same to change the shifter **** there as well? It has a relase lever on the shifter.
Old Jan 1, 2008 | 09:23 AM
Default RE: Shifter
Yes it is.
Old Jan 1, 2008 | 10:04 PM
Default RE: Shifter
Sweet!
Any suggestions for a new shifter?
Old Jan 2, 2008 | 01:14 PM
KnoxVolvo's Avatar
Default RE: Shifter
Do you have to pull up on the shift lever release or just pull the entire ****?
Old Jan 2, 2008 | 06:17 PM
Default RE: Shifter
Never seen an aftermarket one on a 850. Just the stock ones.
Just pull up on the ****.
xDread92x
Jul 21, 2019 04:18 PM
jasond011
Sep 13, 2010 04:02 PM
sandraqu
Dec 24, 2009 02:36 PM
panopticon
Mar 21, 2005 09:38 PM
Kordax
Jun 16, 2004 12:17 PM
