Shifter Lamp
Old Mar 31, 2008 | 03:05 PM
Scott Baret's Avatar
Default Shifter Lamp
My automatic transmission gear shifter's lamp has been out for some time now. I don't drive a whole lot at night but when I do, I have to turn on my reading lamp to see what I'm shifting into.
My questions:
1. What sort of bulb should I use here?
2. Is this a tricky repair? I can handle the tail lights given the instructions in the manual, is this one about the same difficulty or should I have my mechanic do this one?
Old Mar 31, 2008 | 03:45 PM
RedTurbo850's Avatar
Default RE: Shifter Lamp
IT's a special bulb that's 10 or 15 bucks. I forget how much.
As to replacing, I assume it's simply removing the center console which should be pretty easy. Not as simple as the taillights, but not hard enough to have a mechanic replace it.
Old Mar 31, 2008 | 09:42 PM
Maxbaby's Avatar
This has been posted on recently, if you do some searching you should find some stuff last month or so... I did quickly find this post for you which should answer your question...
https://volvoforums.com/m_54374/tm.htm
Old Mar 31, 2008 | 11:59 PM
Psaboic's Avatar
What I did when the bulb burnt out on our 850 was remove the console (which is not too hard, but is a bit tricky) and then access the bulb. The dealer would only sell the bulb and holder as an assemby for like $25, so I took the bulb and holder to my local Radio Shack and got a bulb the worked just fine for $1.89
Glenn
Old Apr 1, 2008 | 12:47 AM
^Wait so is the bulb actually replacable? I haven't investigated but I was under the impression that it was one complete unit.
But if it's just a matter of a bulb and the rest is a holder, I'm for sure going to go get my bulb replaced....
Old Apr 1, 2008 | 08:31 AM
Psaboic's Avatar
Yes, I just replaced the bulb (along with about 8 other bulbs in the various switches and instrument lights that were burnt out when we got the car)
Glenn
xDread92x
Jul 21, 2019 04:18 PM
jasond011
Sep 13, 2010 04:02 PM
sandraqu
Dec 24, 2009 02:36 PM
mdp61377
Jun 23, 2005 02:13 PM
Terence
Feb 20, 2004 02:03 AM
