Should I switch types of oil?
Old Aug 10, 2012 | 11:21 AM
ajahn's Avatar
Default Should I switch types of oil?
I have a 1994 850. I've had the oil changed at my service center since I got the car in 2000. They have been using a synthetic blend 5/30. I was thinking of starting to do my own oil/filter changes to save some money. My wife has a 1997 850, so I could do them both.
Anyway, should I stay with the synth blend or can I change to a full synth? Is it worth it? I live in Texas where the temps in summer are over 100 deg. My car must have about 160K miles on it.
A friend suggested using an oil extractor pump (to get the old oil out from the dipstick area). Any comments on that?
Suggestions?
Thanks
Old Aug 10, 2012 | 01:24 PM
It's great for a boat where you can't get to the drain but I think pulling the plug does a better job.
For my turbo they recommend 15W40 when above 14 degrees F, 10W30 above -4 degrees and 5W30 for under four below.
Old Aug 10, 2012 | 02:28 PM
ajahn's Avatar
Below zero is not a big problem in Dallas TX... Are you saying the lower first number is better for cold weather? I'm confused.
I have been told that you never change the type of oil. If you have used one type, changing it may cause problems. Is that true? I have used synth blend (Casterol 5w/30). I have topped it off with Mobile syngh blend 5w/30).
Should I use something different because of the hot Texas weather? Can I switch to a full synth? Is it better? Car is old and has a lot of miles...
Thanks
Old Aug 10, 2012 | 07:42 PM
Oil is oil. I'll start a fight with that but you can switch and mix all you want. In TX if it was my car I'd run 15W40 synthetic all year. I do believe that synthetic oil is the best and it's worth the extra cost for the value it gives to the engines moving parts. If you can afford a name brand, Castrol, Mobil, Valvoline .... great if not then I'd get a parts house brand the autozone synthetic or oreillys synthetic before I'd run a synthetic blend and I don't use conventional oil anymore even in my lawnmower.
That's just my opinion
The factory recommends 15W40 full synthetic for a Volvo turbo.
Old Aug 10, 2012 | 08:13 PM
I have switched all of my cars to full synthetic, even the one that had 188,000 when I got it. Switching shouldn't matter. It can be the straw that breaks the camels back but if the camel is that loaded down, a pot hole could break it.
Also, the hotter it is the heavyier weight you should use. So, 15w-40 for hot summers is better than 10W-30. I try to use 10W-30 in the winter months and 10W-40 in the summer months. The manual says you should use 15W-40.
PANTYEATR
Jun 10, 2011 06:13 AM
turbo matt
Sep 13, 2010 11:28 PM
Red October
Oct 19, 2009 05:19 PM
halcyon419
Feb 26, 2009 04:39 PM
tipp80
Jul 11, 2005 12:35 AM
