Smelling anti freeze in cabin heat in my 850
Old Nov 8, 2015 | 10:24 AM
diesel850's Avatar
Default Smelling anti freeze in cabin heat in my 850
Hi Folks,
New here but I've had more than a couple Volvos! Last July I picked up a very clean one owner 1994 850 sedan with 124,000 miles on it. Car has been meticulously maintained and I have a 3" stack of service records as proof.
I have put 6K miles on car since purchase with no issues until now. I noticed when the nights started getting chilly that the car wouldn't heat up properly and there was very little cabin heat. I figured changing out the t-stat and the sensor would most likely remedy that but before I got to it I noticed something else. We had a warm rainy day the other day and I turned on the defroster. the car was at normal operating temp and there was plenty of heat coming through the vent. But I can smell antifreeze in the heat. Not sure what this might be due to? Bad heater core? water pump leaking?
Any direction I can receive would be appreciated. I am pretty mechanically able but not great with diagnosis.
Thanks!!
Scott
Old Nov 8, 2015 | 10:53 AM
Psaboic's Avatar
Sounds like a bad heater core. Fell the carpets next to the center console in the driver and passenger footwells. Also, peel them back a little and look around as that is where the heater core is....behind the center console stack. If the carpets are damp/wet, or you see evidence of coolant around there, you have a bad heater core. Not too bad or expensive to replace.
Old Nov 12, 2015 | 04:49 PM
firebirdparts's Avatar
Fix it quick! The heater cores are easy to get to (thank goodness) but the plumbing through the firewall is a little bit fragile. Look at RobertDIY video on youtube, he does a great job.
Old Nov 14, 2015 | 08:21 AM
diesel850's Avatar
Default Thanks
Thanks guys, I have the core on order. I'll let you know how it goes. I found a few helpful vids on the tube of you.
Ashokan1
Oct 11, 2013 02:56 PM
97850glt
Oct 11, 2013 02:51 PM
04XC90T6AWD
Sep 23, 2009 07:41 AM
tr_car_nut
Aug 26, 2009 07:15 PM
colgate41
Apr 23, 2006 09:54 PM
