smoke
Old Jun 1, 2008 | 06:51 PM
jberrocal's Avatar
Default smoke
Ihave a '97 850 glt 2.4 turbo.I just put a new turbo on now whenI am driving and let off the gas and get back on the throttleI get a puff of blue smoke.It dosen't smoke at idle or at speed just when you let off the gas and back on again.Can anyone help?
Old Jun 1, 2008 | 07:36 PM
JPN's Avatar
JPN
Default RE: smoke
Somehow oil is still burning in the combustion chamber. It is probably from the turbocharger or from the cylinder(s). See what Moderator Tech has to say on this. Any external oil leak?
JPN
Old Jun 2, 2008 | 08:28 AM
Psaboic's Avatar
Default RE: smoke
HOw many miles on the car? What is the condition of the engine? Could be anything from assembly oil from the new turbo burning off to bad riungs, bad valve guides, etc...
Glenn
Old Jun 2, 2008 | 05:59 PM
Default RE: smoke
Vent system clogged?
Was the old turbo burning oil?
Old Jun 4, 2008 | 06:57 PM
jberrocal's Avatar
Default RE: smoke
the volvo has 200,000 mil on it but it runs great no power loss no noise i did notis a small amount of oil on the back of the block just under yhe turbo but the turbo seems dry
Old Jun 4, 2008 | 07:00 PM
jberrocal's Avatar
Default RE: smoke
the old turbo was locked up i dont know if the old one was burning oil. what vent system can be blocked i am new to turbos so any help would be great
Old Jun 4, 2008 | 07:03 PM
jberrocal's Avatar
Default RE: smoke
i did see last night under the turbo on the block was leeking not the turbo but i cant see whear it is coming from
Old Jun 4, 2008 | 08:36 PM
JPN's Avatar
JPN
Default RE: smoke
The old turbocharger locked up due to:
- Oil starvation due to low oil or neglected oil change.
- Lack of cool-down idle after a prolonged freeway run in a hot climate.
- Lack of coolant supply (unusual, unless the coolant level is low).
Oil leak at the bottom of the oil return line is a known problem and it should not cause smoke from the tail pipe. Have the seal ring replaced. If the leak is from the oil supply to the turbocharger, have the problem corrected. Pics would be a great help.
I recommend using synthetic oil for turbocharged engines.
JPN
casperskewl
Apr 30, 2021 05:31 PM
royalslover
Sep 20, 2019 02:43 PM
jay philoon
Nov 6, 2005 03:41 PM
cool_guy_jay
Sep 27, 2005 10:35 PM
montalvo
Mar 16, 2005 04:17 PM
