smoke on radiator
Old Dec 2, 2011 | 11:46 AM
slimflex2's Avatar
Red face smoke on radiator
hey guys l need your help.
l see white smoke coming up from the drivers side on the upper side of the radiator.l mean where the transmission hose is connected to the radiator.whats going on.
Old Dec 2, 2011 | 07:36 PM
If the smoke is coming from your rad, I guess it's leaking. You can have it checked out closer by a pro.
Old Dec 2, 2011 | 10:19 PM
Have you noticed you are low on coolant at all recently or have you noticed any coolant below it?
If you get in there with a light and look closely you may find a whitish, chalky trail from the dried up coolant you can follow up to the leak. You may have a crack in the end tank, usually a plastic tank. You may have a seam leak where the aluminum core is crimped to the end tank or one of the fins might have a hole in it. You need to get in there with a light and see what you can see.
If you still find nothing you might want to get a loaner cooling system pressure tester from an auto parts store. You pump the system up and then hopefully it's leaking enough you can see it.
royalslover
Sep 20, 2019 02:43 PM
mikeawd850
Nov 30, 2012 02:26 AM
white83glt
Mar 24, 2011 09:36 PM
cool_guy_jay
Sep 27, 2005 10:35 PM
montalvo
Mar 16, 2005 04:17 PM
