Spark plug help
Old Nov 6, 2019 | 09:41 PM
Ruben Rodriguez's Avatar
Default Spark plug help
Ok so its time to do maintenance on my volvo cause for some reason its having problems with power at the top end (high rpms) i went to autozone to get spark plugs but like always they try to sell the expensive they try to sell me the laser spark plugs because of better response is it true?? I change the spark plugs 1 time a year becuse i put presure on my engine i have a ard computer intake catless and its running 16 to 17 psi i put e85 now and then but i would like to know what you guys recommend?? And thanks for your time ✌
Old Nov 6, 2019 | 10:33 PM
best plugs for an 850T are OEM or old school copper core plugs. The newer iridium etc plugs don't work as well on older engines which don't have direct coils. Also make sure the gaps are to spec - don't assume they are gapped correctly new out of the box. Have you upgraded any of the ignition components?
Old Nov 7, 2019 | 03:20 AM
tukulnana's Avatar
+1
Old Nov 7, 2019 | 02:53 PM
firebirdparts's Avatar
+2. Copper plugs
Old Nov 8, 2019 | 06:41 PM
Default Thanks
Thanks cooper i will get also yes i ran into that problem when i had the car for the first time i did a full tune up and when the car build boost it makes pops and flames at the exhaust and find out they were gap to a non turbo volvo 850 🤣
Old Nov 9, 2019 | 04:48 PM
your wires also have a date code on them. If they are older than 5 years, time to replace. One time I thought mine were good but changes them anyways, only to fine it was corroded under the boot at the distributor...
Old Nov 10, 2019 | 11:40 PM
Thanks that will be changed two i have full warranty on wires,distribution cap and rotor also i will replace pcv sistem fuel filter and all them goodies to make it run as good as i can
Old Nov 12, 2019 | 07:05 PM
860ARE's Avatar
Man especially with the turbos order OEM volvo plugs From FCP euro..free replacement forever and in telling you your car will like them... 93 octane as well as full synthetic oil... This things are not overkill in these cars... my 850R has 340,000 with a recent head job and still rolling daily....
Dc740gl
Feb 16, 2018 05:11 PM
ShowTek
Jul 1, 2010 01:22 PM
bytown
Mar 5, 2009 06:45 AM
Beardog
Feb 7, 2009 01:38 PM
ROBLU540
Nov 13, 2007 06:23 PM
