Special Turbo items...???
Old Mar 8, 2007 | 10:46 PM
RedTurbo850's Avatar
Default Special Turbo items...???
So I just heard the other day you're supposed to let the turbo cool down a little bit after you drive and idle? How does this cool the turbo down more than if you just turned the car off?
And are there any other special turbo items that I should know...??
Old Mar 8, 2007 | 10:53 PM
huzzsaba's Avatar
Default RE: Special Turbo items...???
I have the exact same question........
Old Mar 8, 2007 | 10:56 PM
xps's Avatar
xps
I must say thats a weiird one, but I don't think it could be true.
Old Mar 9, 2007 | 03:14 PM
B1mmer's Avatar
Oil cooled turbos have been known to coke the oil in the turbo if you shut them off after hard use. This over time will kill the turbo. For general driving, you are fine to shut down immediately, but letting the car idle for a minute or so will help cool the turbo if it's been driven hard.
You can install a 'turbo timer' that will keep the car running even after you shut off the ignition and remove the key until the car's turbo reaches the cool down temperature. From what I've read though, these cars tend not to need it. - AB
Old Mar 9, 2007 | 03:36 PM
Psaboic's Avatar
Concur with what B1mmer said.
Usually, unless you come screaming off the highway and shut the car down right away, you shouldn't have any troubles. In fact, if you dirve slowly through a neighbor hood a minute or so before shutting down after a freeway run, you should be fine.
What I do is if I have been driving on the freeway for awhile and pull in to a gas station or rest area, I will let the car idle for about 2 minutes before shutting it off. Another thing is that when I pull into my driveway, I put it in park and let it idle while I get my junk collected and other stuff put away in the car (CD's, sunglasses) That takes a minute and by then the turbo has cooled a bit and is ready for bed.
Old Mar 9, 2007 | 06:01 PM
JimKW's Avatar
Yes if running hard you should let the turbo cool down for a minute or two. I very rarely do this and have never had one of my turbos go on any of my Volvo's. If I'm on the Interstate and pull into a rest area, and I don't have to pee too bad, I will let it cool down for about a minute. Most of the time I can't hold it any longer than that though. I don't think my wife ever does the cool down thing though, and she puts more miles on the cars than I do.
batex
Dec 14, 2011 07:04 PM
75ohm
Mar 2, 2011 08:06 AM
ddvman
Dec 12, 2010 10:45 AM
xtremes07
Feb 16, 2009 02:08 PM
lenniefoug
May 31, 2005 08:11 PM
