Speedometer Died
Old Dec 8, 2008 | 08:31 AM
bashk's Avatar
Default Speedometer Died
Hello Folks,
It is about 13 degrees F here in the northeast and not sure if that's the reason but I noticed that my speedometer and odometer died this morning. The turbo needle and RPM gauges still work.
Is this going tobe an expensive repair? I won't attempt to do it myself.
Thanks in advance,
Bash
Old Dec 8, 2008 | 09:03 AM
Default RE: Speedometer Died
Is the ABS light on?
Old Dec 8, 2008 | 09:33 AM
bashk's Avatar
No, everything else seems to be running normal.
Thanks,
Bash
Old Dec 8, 2008 | 09:49 AM
That is odd them the speedo's usually never fail only the odometer.
But I wonder if it is still related to the ABS module.
Old Dec 8, 2008 | 10:15 AM
bashk's Avatar
I'm on the phone with my mechanic, he's talking about something as simple as a fuse.
or as severe as the pulse generator.
He's also giving me a guesstimate on the repair $30 - $45 for the cable and 1 to 1 1/2
hours of labor if that is the scenario. If itis thethe pulse generator:
The whole assembly (odometer, RPM, Turbo) head
assembly could cost $300 - $350 used and $800 for a new head assembly.
Your thoughts please.
Thanks,
Bash
Old Dec 8, 2008 | 10:17 AM
Someone really needs to get in there and start checking. The ABS module sends signal to the speedo so things need to be gone through to see where the signal is missing from.
willietopz
Aug 1, 2007 02:54 PM
code33
Apr 27, 2006 08:58 PM
seattlevolvoguy
Jan 1, 2006 05:31 PM
proudmonkey
Jun 20, 2005 11:29 AM
JimKW
Jun 9, 2005 10:17 AM
