Speedometer failing?
Old Oct 18, 2006 | 10:31 AM
jtvrba's Avatar
Default Speedometer failing?
I own a 1995 850 wagon.
I've just noticed that the speedometer is starting to go on the fritz!
How difficult is this to replace? I'm assuming that it is electronicly controlled....
Old Oct 18, 2006 | 04:04 PM
code33's Avatar
Default RE: Speedometer failing?
The plastic gears for the speedo are a common problem.
Possible source:
http://www.odometergears.com/subpages/volvo.html
Old Oct 18, 2006 | 05:25 PM
jtvrba's Avatar
Auto house sells a speedometer sensor...What is this for then?
Old Oct 18, 2006 | 06:57 PM
B1mmer's Avatar
The common thing to have happen is that the odometer quits, due to a gear inside the housing breaking. This is a very common and easy repair, thus, that's what code 33 was referring to.
From your description, I'm assuming that speedometer is not working, not the odometer. In that case, it could be the speed sensor (like you spoke about). IIRC there is no cable for the speedometers on the 850's. I bet Tech knows a methodology to test the speed sensor. - AB
Old Oct 19, 2006 | 03:34 PM
jtvrba's Avatar
Correct B1mmer. The speedometer works occasionally. I haven't checked the odometer, I assumed the one wouldn't work without the other.....
Old Oct 21, 2006 | 12:30 PM
Do you have any ABS codes?
nick54
Aug 6, 2007 04:41 PM
Apex
Mar 9, 2007 01:26 AM
petercfoy
Jan 18, 2007 08:47 PM
blackstarpower
Jan 12, 2007 10:44 PM
Dave767
Jul 14, 2006 05:35 PM
