Speedometer/Odometer not working all the time.
Old Feb 24, 2006 | 08:32 PM
lisrobbe's Avatar
Default Speedometer/Odometer not working all the time.
I recently bought a used Volvo 850 T5 Wagon and after driving it for a week or so noticed that the Speedometer works intermittenly. I took it to a mechanic and he changed the sensor's as well as replaced the ignition cylinder and I still have the same results. Does anyone have any insight to what the problem might be and the fix? Any help would be greatly appreciated.
Old Feb 24, 2006 | 08:55 PM
Default RE: Speedometer/Odometer not working all the time.
Is the ABS light on?
What year is the car?
The odometer might be a different problem then the speedo problem.
Old Feb 24, 2006 | 10:30 PM
lisrobbe's Avatar
No the ABS light is not on. It is a 1997. I read somewhere on the internet that if the cruise contorl works it might mean that the Speedometer is the sole problem and needs to be replaced. Is this true?
Old Feb 25, 2006 | 01:00 AM
If the ABS module is bad it will do that to the speedometer as well.
You might want to try to have the codes pulled from the ABS module. The light might not be on but it may still have codes.
Old Feb 27, 2006 | 09:16 PM
lisrobbe's Avatar
Thanks for the suggestion. One thing I forgot to mention to you is that if I turn the ignition key when the car is running it also activates the speedometer to begin working again for a short time. Have you heard of that efore as well?
Old Feb 27, 2006 | 09:50 PM
The electrical part of the ignition switch could also be bad.
my92940GL
Dec 28, 2015 04:22 PM
Aimes87
Sep 11, 2013 04:03 AM
janeofdrama
May 24, 2010 08:02 PM
vanagon
Apr 12, 2009 10:43 PM
jtvrba
Dec 13, 2006 08:36 PM
