SRS code 1-1-1 - warning light still on ?
Old Apr 5, 2011 | 02:47 AM
jadalber's Avatar
Default SRS code 1-1-1 - warning light still on ?
I had two fault codes , 2-4-2 and 1-2-1 . After reset the code 1-1-1 came up, but the light is still on ? I checked the code after a short trip and it still shows 1-1-1.
Anoyone who have the same problem ?
Old Apr 6, 2011 | 07:11 AM
Rickford's Avatar
Did you clear all the codes first and then 111 came back? You must clear all codes first then drive it. Also need need to know year of vehicle etc. If you want help you must include all the info.
Old Apr 7, 2011 | 06:51 AM
jadalber's Avatar
I'v found that ingnition have to be turned off, and on again after the reset in order to find out if the fault have disappeared.
That's the reason why the lamp is still on while the led is showing 1-1-1.
lemmon13168
Aug 31, 2014 01:27 AM
Marke
Dec 3, 2009 03:25 PM
Sparky4688
Sep 26, 2009 06:22 AM
Stuart
Jul 2, 2008 06:57 PM
fopdod
Jan 18, 2005 06:45 PM
