How about these rings for B5234T rebuild?
Old Mar 28, 2011 | 06:24 AM
1996850turbo's Avatar
Default How about these rings for B5234T rebuild?
Found these rings (I think for VW) but are the same spec as the B5234T rings.
Brand Sealed Power
Manufacturer's Part Number ZE494K
Part Type Piston Rings
Product Line Sealed Power Performance Piston Ring Sets
Summit Racing Part Number SLP-E-494K
UPC 087674939126
Bore (in) 3.189 in.
Bore (mm) 81.000mm
Top Ring Included Yes
Top Ring Thickness 1.5mm
Second Ring Included Yes
Second Ring Thickness 1.75mm
Oil Ring Included Yes
Oil Ring Thickness 3.0mm
Oil Ring Tension Standard
File Fit No
Gapless No
Top Ring Material Iron
Top Ring Facing Material Moly
Second Ring Material Iron
Second Ring Facing Material Cast iron
Oil Ring Material Chrome plated carbon steel
Quantity Sold as a set.
These appear to be the same spec as the stock rings in the motor. The difference being they are only $74 for a set of 4 cylinders. The stock rings I have found are like $54 PER Cylinder. I can buy two 4 cylinder sets and have extras if I run into an issue.
Old Mar 28, 2011 | 04:58 PM
ed7's Avatar
ed7
Just call and ask for Sealed Power ring set for your Volvo; a good common brand that many folks carry or can get. Or Mahle, which is likely the brand pistons that you have.
You can't mix brands in this situation.
Figure out what you have FIRST, then get what you need.
Ed
Old Mar 28, 2011 | 05:12 PM
MattyXXL's Avatar
I would also contact VMS, they used to sell Ross Moly ring sets for the 850...
Old Apr 7, 2011 | 01:11 AM
I have actually found a set of Total seal rings for the stock pistons for $210 with a gapless second ring. They are same specs as stock rings and use a gapless second ring and improved oil ring design. Gonna run with those as they are in between the price of the others and stock.
Old Apr 7, 2011 | 11:29 AM
kockyhardrockr's Avatar
What other parts were you considering over stock for your rebuild? I'm curious because I plan on the same rebuild in a few months.
Detailing855
Mar 26, 2011 11:36 AM
T3AMVOLVO720
Aug 30, 2010 09:27 PM
T3AMVOLVO720
Feb 3, 2009 02:30 PM
MikeySq
Nov 12, 2006 12:07 AM
yman
Jun 7, 2006 04:04 PM
