SRS Dash Light Is On! Crash Sensor bad??
Old Feb 27, 2007 | 08:41 PM
oldbug's Avatar
Default SRS Dash Light Is On! Crash Sensor bad??
I have a '93, 850 and am getting Fault Codes 2-1-2 (Driver's air bag, open ckt) and 2-2-2 ( Psgr's air bag, open ckt). The wiring from the air bag connectors to the crash sensor does not show an open ckt. Could it be a bad crash sensor? I find it hard to believe that both air bags are bad. The car has been sitting for a while!!
Thanks,
Tom
Old Feb 27, 2007 | 10:59 PM
JPN's Avatar
JPN
Default RE: SRS Dash Light Is On! Crash Sensor bad??
Hi Tom,
Volvo's self-diagnostic is noted for being inaccurate. You might be able to reset the codes & clear the dash warning, but here's a quote from Haynes:
"It is imperative that any other work involving the SRS components is entrusted to a Volvo dealer"
Haynes likes to say "entrust it to a Volvo dealer" way too often[8D]. But in this case, you may not have an option but make a donation for a dealer.
JPN
Old Feb 28, 2007 | 12:19 AM
RedTurbo850's Avatar
Go to Autozone and reset the code...See if it comes back before you make any repairs...
Old Feb 28, 2007 | 09:31 PM
ORIGINAL: RedTurbo850
Auto Zones scanner won't work on OBDI
But I have seen the air bags go bad at the same time.
Will the codes clear?
Old Mar 1, 2007 | 02:53 AM
oldbug's Avatar
I'm going to pick up a SRS test resistor from Volvo later today. Than I can check to see if the airbags are bad!!!
I was going to fabricate a test resistor, but, can get the real thing from Volvofor $30 which seems reasonable enough.
Will report back on my progress!!
Appreciate the inputs as this is my first 850!!
Tom
Old Mar 1, 2007 | 09:54 AM
axelm's Avatar
www.obd-2.com has a scanner for USD120 that according to the author can reset the SRS light, oil light, MIL, and read Volvo extended codes.
I bought one but my car has European software and it laughs at OBD2 protocol commands. :-(
The author told me that he will write some software so the scanner can talk to my onboard electronics. Let see how it goes.
chipaco
Aug 29, 2013 04:39 PM
lister99
Dec 28, 2012 10:46 PM
fisherman1
Jun 14, 2011 06:07 AM
crosby1
Nov 21, 2010 04:08 PM
Sparky4688
Sep 26, 2009 06:22 AM
