SRS and now ABS lights
Old Jul 30, 2005 | 12:44 AM
Blondy44458's Avatar
Default SRS and now ABS lights
Hello there; Lately I replaced the instrument cluster to fix the broken odometer. Of course now I know I could have purchased the gear, but oh well! I wanted to drive the car before installing the dash and airbag so I could check the odometer. It worked. Forgot to turn the key on to put battery - lead back on to remove the air bag light, so now I sarted over and tried many times - bat. term off, then key on #2 and install, but still the SRS light stays on. Sooooooooo I cleared all the codes I had in A3 and now ofcourse my problem worsens by now having an ABS light on along with my SRS light! lol Any suggestions from any one? Thank you; Steve
Old Jul 30, 2005 | 09:27 AM
Default RE: SRS and now ABS lights
Did you remove the entire dash pad?
Did you disconnect the passenger airbag?
Sometimes the ABS light won't go off till you drive about 20MPH.
Alyson
Dec 6, 2010 11:30 AM
slider 96 850r estate
Oct 28, 2010 04:36 AM
FASTER
Sep 7, 2010 05:48 AM
pj91gsx
Jan 25, 2010 08:07 PM
Dainos
Jul 14, 2009 11:03 PM
