SRS troubleshooting
Old Dec 17, 2007 | 10:24 PM
stecz's Avatar
Default SRS troubleshooting
the SRS light in my '93 850 is on...
I checked the codes: 2-1-2 - open circuit on driver's side airbag
I can't reset it, which leads me to believe it's a real problem and it's not intermittent.
The question is, are there any good resources to help with trouble shooting? Basically, where do I begin? Any common failure points to check first?
John S.
Old Dec 18, 2007 | 09:12 AM
xpiecemealx's Avatar
Default RE: SRS troubleshooting
I dont have the code but I have the same car and same problem. If you find out anything please let me know.
Mat
ORIGINAL: stecz
John S.
Old Dec 18, 2007 | 08:17 PM
I will tell you what it usually is.
1.Bad SRS contact reel. The plastic piece behind the steering wheel.
2.Bad Air bag.
Old Dec 18, 2007 | 09:54 PM
stecz's Avatar
So the "contact reel" sounds like, remove airbag, remove wheel and that is the piece that lets the wheel rotate and still maintain electrical contact. (assuming it's not the airbag itself)...
Old Dec 18, 2007 | 09:59 PM
You are correct.
The plastic holding it to the column is very brittle when old. The mounting tabs will break and it will try to turnwith the wheel and end up breaking it internally.
If you remove the black covers usually you will see the clear plastic broke.
ALSO note: Mark the steering wheel before removing it.
Old Dec 19, 2007 | 08:54 AM
stecz's Avatar
is the part expensive? should I get one before I tear into it, or should I tear into it first and then have the car undriveable while I get the part after I verify that is the problem? (not a huge issue...)
John
Old Dec 19, 2007 | 10:08 AM
JimKW's Avatar
No matter how much you spend for the part you will have to go to the dealer to have the SRS light reset. When and independent guy did my evaporator he also found the problem causing my SRS light to come on. When he put it back togehter, he had to take it to the dealer and spend $117 just to have them reset the light. He has almost every possible diagnostic piece of equipment too, but not that one.
Old Dec 19, 2007 | 05:43 PM
Jim he has a 1993 he can reset it himself.
Not exactly sure how much it is. I would call and check.
Old Dec 19, 2007 | 08:29 PM
<insert swear word here>
Old Dec 20, 2007 | 09:56 AM
stecz's Avatar
the part is almost $200 from the volvo dealer.... I'll take it apart, make sure the reel looks bad and then order one. It will only take a day to get the part, so that won't be bad...
Old Dec 20, 2007 | 07:14 PM
You should be able to Ohm it and tell if it is good or not.
Old Dec 21, 2007 | 06:33 AM
JPN's Avatar
JPN
In case if you need directions...
JPN
[IMG]local://upfiles/6892/8E1A931802A14325A298A13B74527485.jpg[/IMG]
[IMG]local://upfiles/6892/D887CAC997134750BA91D3210155D879.jpg[/IMG]
[IMG]local://upfiles/6892/183E4ECF15544100A08955340F75E92A.jpg[/IMG]
[IMG]local://upfiles/6892/B2237FA7B55C4C7B88ECF0DB35E27CF9.jpg[/IMG]
Old Dec 21, 2007 | 06:35 AM
JPN's Avatar
JPN
2nd half.
JPN
[IMG]local://upfiles/6892/1A80A7C4C9634833BD9C1573DAE7DD0F.jpg[/IMG]
[IMG]local://upfiles/6892/98D60AA9895D4E23AAB6DA60925BB14E.jpg[/IMG]
[IMG]local://upfiles/6892/233D57F216FE4585875B6C6CE55BB31B.jpg[/IMG]
Old Dec 21, 2007 | 07:59 PM
http://cgi.ebay.com/ebaymotors/1996-...em150164677109
That might be what you need.
That is the SRS contact reel.
Old Dec 27, 2007 | 09:31 PM
stecz's Avatar
cool thanks
Sparky4688
Sep 26, 2009 06:22 AM
clifsox
Mar 20, 2008 08:04 PM
kristen1nv
May 31, 2007 11:09 AM
960Tuck
Oct 6, 2006 09:05 PM
maph
Aug 5, 2005 09:34 PM
