Starting Issues
Old Feb 15, 2014 | 04:35 PM
drklive's Avatar
Exclamation Starting Issues
I have a 1996 Volvo 850 Turbo. It ran just fine until today. The car will crank but wont start.
I started smelling gas in the car for a couple of minutes and then later realized that the engine was revving at about 4,000 rpm for no reason. I felt a slight pull at first but I thought it was something else. I then put the car in neutral and it was just revving at a steady >4,000 so I shut it off. Sadly it wouldn't start again. It'll crank but wont turn over. Could it be that the the throttle is stuck? Or maybe an idle sensor issue? I just wanted to get an idea of what the problem is before I got it towed to the shop.
Old Feb 16, 2014 | 03:09 PM
Hi and welcome to the site.
Did you go check the throttle to see if it was stuck? Takes about 2 minutes.
Not sure if it restarted then went to 4,000 RPM's.
burtonsnowbird
Feb 11, 2006 05:02 PM
burtonsnowbird
Feb 7, 2006 01:07 AM
splash114
Jan 29, 2006 10:36 AM
PhilM
Jan 23, 2006 04:21 PM
