Swaybar bushings ARE replaceable!!!
Old Oct 27, 2011 | 09:21 AM
kkarasch's Avatar
Default Swaybar bushings ARE replaceable!!!
Just installed mine last night. It takes some work to get the old ones off but took me about an hour. Cut off the brackets with a cutoff wheel. Then with pliers remove the plastic outer shell of the bushing. Then rip off as much rubber as you can with a razor, screwdriver, etc. Lastly used an acetylene torch to burn/singe the rubber while using a paint scraper and wire brush to remove the remaining material. Here is a pic of the final product. Energy 9.5124R install. $19 at autozone.
Old Oct 27, 2011 | 10:51 AM
boxpin's Avatar
Looks good...where did your rack & pinion go?
Old Oct 27, 2011 | 11:12 AM
kkarasch's Avatar
The new one got installed immediately after
Old Oct 27, 2011 | 01:42 PM
Or .... you can get the one that's greasable. I only say that because I've had them squeak a year or two down the road and it's a pain to lube them after they are installed and starting to rust in. Energy Suspension PN 9.5157R for 19.99 at AutoZone. These are 20.5mm or 13/16" also.
Attached Thumbnails Swaybar bushings ARE replaceable!!!-sway-bar-bushing-energy-greasable-9.5157r.jpg
dsutton
Mar 21, 2025 05:49 AM
timwu12
Nov 29, 2009 08:31 PM
Platinum52
Jul 17, 2009 07:33 PM
ShaginWagon
Apr 11, 2009 10:24 PM
TheSaint
Suspension
Feb 12, 2007 12:13 PM
