A/t tranny issu3s clu3l3ss
Old Mar 7, 2009 | 05:10 PM
T3AMVOLVO720's Avatar
Default A/t tranny issu3s clu3l3ss
ok so put the motor together everythings fine dropp it in start it and everythings fine then put in reverse to check for any leaks on the garage floor
stop put in it park
shut it off
now it starts but i put it in reverse,drive,2 and Low and doesnt go any where im clueless its got fluid in it and the fly wheel is bolted to the torque converter any help?
Old Mar 7, 2009 | 05:11 PM
and there is no tranny lights nothing even just bought a tranny
ECU.. the cable moves the lever above the tranny but it just doesnt move forward or backwards..you dont feel it kick into gear.
Old Mar 8, 2009 | 09:30 AM
Scotland77's Avatar
you say the torque converter is bolted to the flywheel, but do you remember if the splined shaft that comes out of the trans and mates to the converter was all present and correct.
Not sure on Volvo's as I am still new to these vehicles (only had mine for a couple of weeks), but this very thing almost happened on my Ford
Old Mar 8, 2009 | 10:39 AM
Are the axles snapped in all the way?
Does the speedo work?
Old Mar 8, 2009 | 11:43 AM
im sure that the axles are in and the shaft for the torque converter is in its right groove but when i put it in reverse or drive it doesnt budge but it did move two feet right after the first start then that was it
but it still goes in park
no noises at all from the transmission areaa
can a torque converter just go bad like that
is there a special way to fill up the transmission
from dry or near empty
i never drained no fluids out of the converter so i dont know whats going on
Old Mar 8, 2009 | 11:45 AM
speedo doesnt work because the wires somehow hot cut somewhere in the motion of driving and i posted a thread asking what colors the wires where so i could see if i could rerwire them but never got an answer on the colors
Old Mar 8, 2009 | 11:46 AM
You need to fill it with it running after the initial fill up through the dipstick tube.
The fluid level is full now with it running?
Maybe the tranny was bad that you bought.
Old Mar 8, 2009 | 07:48 PM
Clavius's Avatar
You sure you hooked up the linkage correctly? As in is there any resistance at all when you bring the car down to R or even D from Park? Only thing I can personally think of myself. Could be something as small as a small wire you forgot to hook back up.
Old Mar 9, 2009 | 02:32 PM
Scotland77's Avatar
I'm not sure that a wire missing could be the cause.
Did I read a few posts back that the car did move slightly at first, I have a hard understanding your text - That being said and this maybe a dumb question but did you check where the shifter linkage attaches to the trans. If the shifter ain't hooked up, it might be in "N" and not coming going into a gear.
Other than that check your fluid level again, it takes a good amount to fill a converter
Old Mar 9, 2009 | 11:40 PM
never took the tranny out just pulled the motor out never even touched the torque converter
but this time i drained the tranny
when i put the motor back in i filled the TC and made sure it clicked in
put the motor in bolted the motor to tranny and screwwed the fly wheel to the TC and filled it up started it and topped it off
it goes in park never touched none of the levers..
put it through all gears and you dont even feel it kick in at all
it like its in nuetral for all gears
but never touched the shifter or anything with the tranny except the fluid
and yes after first start up it went into reverse let it go back 2 feet then put it in park and never went back into any gears after that..
converter is filled
is this signs of a broken or bad converter?
Old Mar 10, 2009 | 12:14 AM
gdog's Avatar
Any error lights on the dash? Any error codes set in the TCU?
My trans acted very strange one time; similar to your experience. Turned out to be the Econ/Sport in an indeterminate position. But I think the up-arrow light was on...
Old Mar 10, 2009 | 10:38 AM
Scotland77's Avatar
Not sure if the TC is bad. If it was working before and you didn't mess with it, it seems unlikely that it would be broken now
If the fluid level is where it should be and the shift linkage is functioning correctly, you may have to start taking the trans out to diagnose the issue
Old Mar 10, 2009 | 11:25 AM
no thats the things it did flash at first but i just topped the trans fluid off and it went off i check the check engine just something about the wastegate nothing about not transmission
im having it towed to a shop today
im tired ive pulled the motor out several times this week
might be for sale after all the problems are fixed
ran out of things to do to it!
Old Mar 10, 2009 | 02:55 PM
bestharry's Avatar
You mentioned some cut wires in a post up somewhere and wonder if some of those wires are part of the shifter solenoids.
Why dont you check another car for those wires and copy the colours?
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
knight rider
Apr 28, 2005 12:20 PM
mr
Apr 19, 2005 10:31 AM
Rammstein
Dec 11, 2004 05:28 PM
ponies
Sep 10, 2004 04:55 AM
