Tachometer goes in and out
Old Sep 7, 2008 | 10:12 PM
litehwk356's Avatar
Default Tachometer goes in and out
my tachometer goes in and out of working, out most of the time, but if i rev it high when its out, it will jump up and then go back down to 0 after i let the throttle down, but is not accurate during this jump. it shows much higher RPM's than the engine is actually running at.
other times it will work fine, no problems, but only once in a while
its a 1993 GLT with 318K miles and a 5spd manual.
anyone have any idea what it could be?
Old Sep 8, 2008 | 08:38 AM
Psaboic's Avatar
Default RE: Tachometer goes in and out
Forum member and moderator Tech will probably have a more specific answer, but my thought is a loose connection at the gauge itself, or a loose connector at where the RPM signal comes from. I can't remember if these cars get an RPM signal from the ignition coil, or a seperate sensor.
Old Sep 8, 2008 | 03:41 PM
litehwk356's Avatar
ok, i can try checking to see what it runs to
Old Sep 8, 2008 | 06:06 PM
Are any other guages doing anything funny?
Old Sep 8, 2008 | 08:07 PM
litehwk356's Avatar
no, the tachometer is the only one that does anything abnormal
Old Sep 8, 2008 | 08:31 PM
The tach might be bad or something in the wiring. You could also try removing the ignition and fuel computers and reinstalling them and see if it helps.
Old Sep 9, 2008 | 05:40 AM
Quick Brick's Avatar
Hello Litehwk356,
I have a previous post with some photos if my dash showing my tach at zero and the speedometer at 80+km/h.
The first time this happened I didnt know what to think.
Ill place a link when I locate is as this only happens once every couple of months. And only for a day or two then things are fine.
Its kind of weird.
[sm=icon_cheers.gif]
terp
Mar 23, 2022 06:28 PM
i_knowthetruth
Dec 19, 2013 08:42 AM
Snooky
Feb 8, 2006 07:30 PM
joelovescarmen
Aug 23, 2005 01:35 AM
