Tachometer problems + loud noise help please
Old Nov 7, 2008 | 04:21 PM
Arsenal6's Avatar
Default Tachometer problems + loud noise help please
So here the situation I have, the other day I was driving the car tacho hits 2500 rpms and is stuck as if that the max it can go, switched into sports mode and back it was some what fine. However the car starts making this weird noise GUNGUNGUNG and I don't know whats going on. Drive home a hour later I start the car and BOOM the car sounds louder than a v10, tried driving it but it tops out at 1400 rpms and doesn't go faster than 30 km. There a huge scent of gasoline inside and outside the car. I had problems starting the car twice before it started gungungunging. I hope someone has a idea or a went through this and hopefully it not a extreme problem. So what your take?
Please and Thanks guys
Old Nov 7, 2008 | 04:31 PM
Default RE: Tachometer problems + loud noise help please
Maybe Mass Flow sensor is bad.
Could be alot of things Any codes on the engine computer?
Old Nov 7, 2008 | 05:04 PM
Arsenal6's Avatar
Codes? I am not sure I am pretty new with car repairs.
Old Nov 7, 2008 | 07:12 PM
Is the check engine light on? If so you need to have the codes read out of the computer.
You also didn't say what year the car is. If it is a 94 or 95 check link to learn how to pull codes.
http://www.troublecodes.net/Volvo/
Old Nov 7, 2008 | 07:30 PM
Arsenal6's Avatar
o sorry mine is a 96 GLE from the link you sent me I would need a scanner. Not sure but can I get one at walmart? Or from a mechanic
Old Nov 7, 2008 | 07:50 PM
You can get one from an autoparts store. Some parts stores will rent them to you.
Old Nov 7, 2008 | 10:20 PM
JPN's Avatar
JPN
Also, try visually inspecting the engine & exhaust pipes when both are cold. With gungungunging I would not restart the car until the problem is identified.
JPN
Old Nov 8, 2008 | 07:17 AM
JPN's Avatar
JPN
As to OBD-II scanner, my favourite is Actron:
http://www.actron.com/whats_new.php
Look around, as some other mfgs may have good products as well. If you do not do a lot of diagnosis, then the cost of a scanner may not be worth it as you can visit an auto parts store and they can pull codes for you.
JPN
Old Nov 13, 2008 | 12:51 AM
Arsenal6's Avatar
it looks like a gap between the exhaust manifold and the rest of the car...could that be the only issue?
I am not from the US so i guess that site you linked me doesn't ship to Canada =P
Old Nov 13, 2008 | 09:56 AM
JPN's Avatar
JPN
I think they do:
http://www.actron.com/terms_conditions.php
JPN
Old Nov 27, 2008 | 12:25 AM
Arsenal6's Avatar
turns out to be the exhaust manifold...the connecting part blew off...
was wondering how does that happen?
Old Nov 27, 2008 | 06:53 AM
Did the nuts come loose?
Old Nov 30, 2008 | 12:09 PM
Arsenal6's Avatar
I am not sure...but the entire head that was connected to the exhaust was practically missing there was a gap altogether
LOVEvolvos
Apr 24, 2012 10:36 PM
Juancho420
Sep 30, 2009 10:38 AM
nightsurfride
Apr 13, 2006 09:13 PM
Snooky
Feb 8, 2006 07:30 PM
joelovescarmen
Aug 23, 2005 01:35 AM
