Tachometer Wiring
Old Nov 29, 2008 | 11:58 AM
litehwk356's Avatar
Default Tachometer Wiring
i have a short in my tachometer, does anyone have a diagram of the wiring and the speed sensor?
Old Nov 29, 2008 | 12:42 PM
billofdurham's Avatar
Default RE: Tachometer Wiring
I hope these help. They are for the '93 model which I believe you have.
[IMG]local://upfiles/4491/4306DF38669741A393A5B629F7D89C1B.jpg[/IMG]
[IMG]local://upfiles/4491/97D928FC8E434CD8AD6433A4CA611E82.jpg[/IMG]
Old Nov 29, 2008 | 09:42 PM
litehwk356's Avatar
yeah, sorry forgot to mention it is a '93, thanks
that looks pretty complicated... is there a sensor on the motor that it gets the signal from, or is it a coil wire, or what?
and are there any things other than wiring that would cause it to go in and out of working?
it seems like it mostly works when it has been sitting for a short period of time, and the engine is cool, then after about 20-40 minutes of driving it usually goes out, sometimes it will come back on, but usually stays out until i park it again.
and when it is out, if i revv the engine to around 3K rpm's, the tach will jump way up to about 4.5K and then when i throttle down it will go right back to zero.
Old Nov 30, 2008 | 07:04 AM
The tach itself might be bad. I have seen a few do that.
Mark Lester
May 1, 2007 09:32 AM
Namniar20
Oct 15, 2006 11:23 PM
nightsurfride
Apr 13, 2006 09:13 PM
Snooky
Feb 8, 2006 07:30 PM
joelovescarmen
Aug 23, 2005 01:35 AM
