Tailgate panel repair kit
Old Apr 20, 2011 | 01:44 PM
Junkyardspecial's Avatar
Default Tailgate panel repair kit
Ive seen the repair kit on the DIY thread but it shows that it is not sold any longer. I cant seem to track it down anywhere. Anyone have a clue where I can find it?
Old Apr 20, 2011 | 02:17 PM
ibified's Avatar
Click HEYUH!:
Tailgate Panel Repair Kit
Old Apr 20, 2011 | 06:31 PM
boxpin's Avatar
I did mine, not sure if I like it. I guess its better than broken.
Suggestion I would offer, when you mount the metal tabs on the panel go to a hardware store and get some door/window insulation, maybe a 1/8 thick. Put it on the surface where the panel will touch the gate to eliminate rattles. Also, the trim that runs up the sides of the window on each side, if you look you will see where it touches the gate, put some there too.
Old Apr 20, 2011 | 07:25 PM
Thanks you two, Ill look into the insulation kit. Mine is pretty loose Im close to just taking it off for now.
Old Apr 20, 2011 | 09:51 PM
vjaneczko's Avatar
I got the kit from FCP, but one year later and it's shot. Problem was they didn't include enough parts - the kit has enough for 4 mounts, but it takes 6 or 8 - I forget how many.
Old Apr 21, 2011 | 02:03 AM
I might just get some gorilla glue to go with it and spread the mounts aprt evenly then glue the rest down.
Old Apr 21, 2011 | 09:14 AM
vjaneczko's Avatar
You may want to hold off on the glue - you'll probably have to open it up to fix the wiper motor, replace the bulbs, or in my case; so you can remove your key from the jacked-up locking mechanism!
There's a post I read a long time ago from someone using silicone to seal it up. That seems to be a better route because it's easier to cut if you need to open it up again. I plan on searching for that thread in a few weeks to do that very thing.
tech
Mar 25, 2012 09:00 PM
Luc L
Sep 10, 2011 07:39 PM
junkprospector
Mar 3, 2008 06:50 PM
Typhoon
Jan 2, 2008 01:01 AM
yellow95
Apr 19, 2006 09:05 PM
