taper player makes words fade
Old 02-17-2008 | 05:29 PM
glt93's Avatar
Default taper player makes words fade
The tape player makes the words of the songs fade in and out can it be fixed or would I have 2 get a new unit
Old 02-17-2008 | 07:21 PM
JPN's Avatar
JPN
Default RE: taper player makes words fade
I would try a head cleaner tape as a cheap trial. Or, you could spray contact cleaner on the inside the volume **** and play with fade & balance control.
Ifit doesn't solve it and if you can afford a new unit, I may consider a new unit.
JPN
Old 02-18-2008 | 10:19 AM
Psaboic's Avatar
Yep, try cleaning it and if not, go for a new unit.
Old 02-18-2008 | 07:56 PM
Maxbaby's Avatar
It might be build-up on the head unit. Cassette tape dragging across the head unit leaves a residue that builds up over a long time. This buildup affects the high frequencies first. It may be that the head itself has finally given in after so many years, but if you haven't been cleaning it regularly, then I'll bet you see improvement with a high quality head cleaner, preferably one that not only uses a cleaning agent but also has the ability to help demagnetize the head. You can usuallyfind a good quality cleaner at a stereo shop for $20. Don't cheap out and buy the $7.98 special and don't use one of those "dry" cleaning cassettes because they don't work.
Old 02-18-2008 | 08:16 PM
JPN's Avatar
JPN
I forgot to mention that one, yes the demagnetiser liquid kit that comes with Q-tips and you physically clean the head with the wet Q-tip. The kit may come with 2 different liquid bottles.
JPN
jackdawson
03-20-2011 01:40 PM
krmgator
07-10-2010 05:59 PM
81sidewayswagon
04-12-2010 11:06 PM
Sambar Stag
08-15-2009 03:17 AM
TheJimbo
10-26-2006 11:16 PM
Quick Reply: taper player makes words fade
