Teck-help w/ rear brakes needed.
Old Feb 20, 2006 | 12:06 PM
m1964's Avatar
Default Teck-help w/ rear brakes needed.
Just ordered rear pads and rotors (from Eeuroparts) -last time I got the pads they came w/ 2 types of the shims -- non-coated shiny ones and another set of black coated shims.
First, I used only the shiny non-coated shims, and the car made some little noise.
I later inserted the coated onesand it has not made any noise since then.
QUESTION -which ones go towards the pad, and which ones to the caliper side?
Thanks
'95 850 GLT non-turbo
'05 XC90 V8 (DF's car) -we like them... volvos
Old Feb 20, 2006 | 08:19 PM
reg's Avatar
reg
Default RE: Teck-help w/ rear brakes needed.
I spray the shims with brake anti squeal.............both sides and no noise. The teflon coated shims are the latest iteration and have a coating (teflon) to keep them from squealing. Your choice.
R.
Old Feb 20, 2006 | 08:47 PM
The rubbery feeling one goes on the back of the pad. The shiny one goes to the caliper.
Install either a Antisqueel or Anti seize or a silicon based grease.
Old Feb 20, 2006 | 10:44 PM
m1964's Avatar
Thanks. I use OEM silicone paste -works well.
Old Feb 20, 2006 | 11:10 PM
ORIGINAL: yurionel
YES IT DOES I LOVE IT!!
Old Feb 23, 2006 | 11:30 PM
m1964's Avatar
Default Tech, Reg -Thanks
Changed rear brakes -not only brakes feel "stronger", also no more vibration I was blaming on front brakes.
Old Feb 24, 2006 | 12:24 AM
Default RE: Tech, Reg -Thanks
Your welcome glad we could help.
kippster41493
Nov 17, 2013 10:50 PM
jtbshaw
Jun 5, 2006 08:47 PM
m1964
Apr 29, 2006 01:43 AM
