thermostat question
Old Mar 5, 2012 | 08:48 AM
cheesenacho's Avatar
Default thermostat question
i have read several posts about replacing the thermostat and none mention using any type of sealant, like liquid gasket. Is the rubber one that come with the new thermostat enough?
Old Mar 5, 2012 | 09:50 AM
schigara's Avatar
Yes. The rubber seal is all you need.
Old Mar 5, 2012 | 10:58 AM
When you have a rubber seal and you use anything between the metal surfaces of the housing you are actually taking away some of the clamping force that provides the seal.
And if you have a chance now would be a good time to get replacement bolts with a hex head at the hardware store and dab a little "anti-seize" on the threads for next time
pharunk
2001-2013 model year XC70
Mar 21, 2015 04:35 PM
Mikedee37
Dec 8, 2010 12:42 PM
dlk1
Oct 19, 2008 10:59 AM
Buck
Aug 23, 2005 09:20 AM
jcmartin
Mar 1, 2005 01:46 PM
