Thermostat and coolant sensor question:
Old Oct 15, 2008 | 07:49 PM
dlk1's Avatar
Default Thermostat and coolant sensor question:
What is the correct thermostat for my '02 V40? I see FCP Groton has three shown: 87, 92 and 104 degrees.
Also, does anyone know the part number for the cooant temp. sensor?
I'm getting repeated PO 117 codes (coolant temp low), so I'm just going to swap out the therm and sensor. I've heard this may be causing my occasional misfires, rough idle and hesitations on hot starts. I've already changes plugs, wires and coils (all OEM).
Old Oct 17, 2008 | 11:00 AM
dlk1's Avatar
Default RE: Thermostat and coolant sensor question:
Anyone?
Old Oct 17, 2008 | 01:09 PM
I can get you an OEM part # for both if that will work?
The S40 has a weird temp thermostat.
But the temp sensor is the same as the S70,V70,S60.
Old Oct 18, 2008 | 09:41 AM
dlk1's Avatar
thanks tech; part #'s will work.
Old Oct 18, 2008 | 09:52 AM
The thermostat kit (thermostat and seal) 271644.
The sensor is 9125463.
Old Oct 19, 2008 | 10:47 AM
dlk1's Avatar
thanks!
Old Oct 19, 2008 | 10:59 AM
Your welcome.
cheesenacho
Feb 29, 2012 09:32 PM
master_pre
Nov 15, 2007 09:10 PM
jcmartin
Mar 1, 2005 01:46 PM
