Throttle Cable... broken?
Old May 18, 2011 | 02:00 PM
tobolate's Avatar
Default Throttle Cable... broken?
When I first bought my 850 about two years ago, it accelerated normally under all levels of throttle, flooring it would result in smooth shifts etc.
One day, it suddenly started sticking at shifting gears when under heavy throttle. This problem started soon after the PNP switch on the transmission was replaced. However I did notice after the problem started, that the car's throttle cable seemed to be broken where it connects to the throttle body. Not the actual metal cable, but the plastic part around it at the bottom.
I'm not sure if it is actually causing a problem, or if its the cause of the hard, or sticking shifts, or if its effecting my mpg, etc. But I'd really to find out if I need to replace it soon.
I've attached a few pictures of the "broken" part its self, and also am attaching a youtube video of it so that you might be able to see if it is acting normally.
http://www.youtube.com/watch?v=khZ5sPLRgLU
Thank you in advance for any advice you can give, or if you need more information, I can provide it.
Old May 18, 2011 | 05:31 PM
Junkyardspecial's Avatar
This happened on a ford Mustang I used to have, It stuck open and blew my transmission, Id try to get it replaced asap, It could jam open and be a dangerous situation in the making.
Old Aug 22, 2011 | 10:33 PM
ded137t5r's Avatar
so did you ever replace the cable? if so, how was the re install? do you have to set everything up or just plug in and go? mines having the same issues
jsj_297
Jun 2, 2012 03:21 AM
kylebooth
May 14, 2010 03:17 PM
BPATR1CK
Apr 6, 2010 02:26 PM
timer00
Mar 3, 2009 08:51 PM
Dainos
Dec 3, 2008 08:29 AM
