Tire
Old Dec 21, 2008 | 05:00 PM
VJZ's Avatar
VJZ
Default Tire
Okay.
The other day I had a tire go flat on me in the front (Front pass. tire).
I went to a junk yard and found a nearly new tire.
Its flat again today.
I know they did a bunch of suspension work before I got the car and the camber is way off because they never aligned it, but I drove on the old tire for a good while before I even had the first on go flat.
The rim has a slight bend but not enough to warrant THIS from happpening twice in a week.
What should I do?
Old Dec 21, 2008 | 05:01 PM
Default RE: Tire
The inside edge burn to nothing and blow it out?
Old Dec 21, 2008 | 05:02 PM
VJZ's Avatar
VJZ
Default RE: Tire
EDIT: That bend is barely noticeable.
Old Dec 21, 2008 | 05:03 PM
Default RE: Tire
But was the belts hanging out on the inside edge?
Old Dec 21, 2008 | 10:47 PM
VJZ's Avatar
VJZ
Default RE: Tire
I didn't really look.
The tire wasn't off the rim and just appeared to be flat.
The other tire that I removed looked completely normal inside and out.
Also, I bought the car a month ago. I had no problems with the tires until Tuesday of this past week.
Old Dec 22, 2008 | 08:26 AM
Psaboic's Avatar
Default RE: Tire
Take the tire to a tire shop and see if they can find anything wrong with it. Could be you just had the bad luck of picking up a nail or something in the same tire. Either that or you have some kids in your neighborhood that are messing with you <grin>
Old Dec 22, 2008 | 08:48 AM
VJZ's Avatar
VJZ
Default RE: Tire
I did get a 225 though.
I didn't think that would be too wide. Wrong?
I hope not.
Old Dec 22, 2008 | 09:14 AM
Default RE: Tire
225 might work.
But if the tire looked pretty good I would check the valve stem and make sure that didn't blow. Or there is a hole in the tire from like a screw or something that you ran over and it came out while driving.
Old Dec 22, 2008 | 10:12 AM
VJZ's Avatar
VJZ
Default RE: Tire
It appears my car is leaking coolant as well.
I think I tore a hose on ice or something.
UGH
Old Dec 22, 2008 | 10:30 AM
Default RE: Tire
Sorry man that sucks.
Old Dec 23, 2008 | 11:29 AM
VJZ's Avatar
VJZ
Default RE: Tire
Hey nothing else is down there that smacking on ice could cause a leak right?
I ordered a lower rad hose. hopefully that is all it is.
Old Dec 23, 2008 | 12:14 PM
Default RE: Tire
Hopefully it isn't the radiator itself!!
Old Dec 23, 2008 | 03:01 PM
VJZ's Avatar
VJZ
Default RE: Tire
Radiator is cracked by the lower hose.
drips out right by the lower hose where the plastic tank meets the metal core of the radiator.
Anyone got a turbo radiator to fit my 96 wagon?
How hard is the radiator job?
Old Dec 23, 2008 | 03:20 PM
Default RE: Tire
It is kind of a pain and a little time consuming.
heyitsomid
Oct 11, 2008 06:46 AM
HummerGuy
Oct 10, 2008 08:02 AM
kcw12
Jun 10, 2008 08:48 PM
daisydaisy
Jan 26, 2006 11:52 PM
