Tire rubbing
Old 07-21-2010 | 01:11 PM
mudpie's Avatar
Default Tire rubbing
I currently have two 850s, and I've had 3 others. One was a n/a, the others were/are turbos. All except the n/a rubbed tires on the plastic wheel well liner when turned to full lock. Some only on the right side, some on both, but they all did it, and it didn't matter if it was the stock wheels or an aftermarket set that I swap around from car to car.
Given that all 4 of my turbo cars do this, I'm guessing this is fairly common?
Old 07-21-2010 | 01:48 PM
vjaneczko's Avatar
What are the tire sizes? Compare them with the label on the inside of the gas door, which indicates the factory size.
Old 07-21-2010 | 04:30 PM
ibified's Avatar
Mine rub VERY slightly at full lock. im running a 205/55/16
Old 07-22-2010 | 07:52 PM
I just lost a tire because of this problem. To top it off, my forward splash gaurd was missing 2 securing bolts. I installed them and it appears to have solved the problem.
Old 07-23-2010 | 12:09 AM
toddro91482's Avatar
This is fairly common on lots of models. The best and cheapest fix I have found is to remove the turn stops, put a washer between the turn stop and bolt back together.
Old 07-23-2010 | 12:38 PM
boxpin's Avatar
205/50 16s ...anything larger and you pay the price of having good looks.
Old 07-24-2010 | 12:54 PM
mudpie's Avatar
The fuel door only lists the 15" size. I'm guessing somebody swapped the door somewhere along the way, maybe when the hinge broke.
One car has 215-45/17 that I bought, and the other has 205-55/16 that a previous owner bought. I guess I never realized that things were that close together in the wheel well that a couple milimeters would make a difference, especially given that it's such a slight variation in tire size on a factory wheel. It's not like I'm trying to cram 20's under there.
Thanks
Old 07-24-2010 | 01:38 PM
boxpin's Avatar
Thanks
I believe N/A's list 15s and Turbos list 16s. Regardless, my experience...205/55 16's rubbed and my 215/45 17s rub. I just know where to stop before lock.
Old 07-24-2010 | 08:35 PM
One of my favorite Volvo features was how tight of a turning circle my 700 and 900 series have. IMO the 850 R is weak in that area. I understand that a FWD car had a harder time at this but I'm getting use to it.
celjock
04-16-2011 03:55 PM
polloloco911
10-09-2010 03:15 AM
Hugh G Rection
07-02-2007 12:53 PM
EdLuVa
01-15-2007 09:51 PM
vicki
05-12-2005 10:37 PM
