Torque value needed
the 2 nuts: tighten to 48 ft/lb and then turn another 60 degrees
The 2 bolts: if they are M8 bolts, tighten to 13 ft/lb and then another 90 degrees, otherwise, tighten to 26 ft/lb and then another 60 degrees. Note that these are "torque to yield" fasteners- Volvo says you can re- use the bolts one time, but if there's any doubt as to whether they've been removed before, you should go get new ones, as you risk breakage if you reuse them a second or subsequent time.
dpagini
07-02-2014 07:31 PM
mountain lion
02-27-2011 06:34 PM
