Torque Wrenching crankshaft bolt...is it absolutly needed?
Old Feb 27, 2011 | 02:21 PM
mountain lion's Avatar
Default Torque Wrenching crankshaft bolt...is it absolutly needed?
Can I just tighten that bugger dang tight and-then-some and be on the road? Or do i wait six months for a torque wrench to arrive and torque the bolt to 44 ft-lbs and and additional 90 deg for good measure?
Old Feb 27, 2011 | 02:35 PM
i forgot my kudos< ty everyone !!
Old Feb 27, 2011 | 04:46 PM
Titan Joe's Avatar
I've never used one for that and never had one fall off. I've also only taken two off. So I worried about it, but nothing happened. Why do you need to wait 6 months?
Old Feb 27, 2011 | 04:56 PM
swiftjustice44's Avatar
Personally, the only time I use a torque wrench on a crank bolt is when I'm building a motor.
On the car, I use an impact wrench and it gets tightened a good bit more than specs of 44'lbs plus 60 degrees. The main thing is to get it good and tight. A crank bolt falling out or even being loose can cause the key way to wear and in extreme cases, necessitate a new crankshaft.
Old Feb 27, 2011 | 04:57 PM
ed7's Avatar
ed7
Air impact always worked for me.
Ed
Old Feb 27, 2011 | 06:34 PM
Right on!!
volvo745newbie
May 11, 2015 11:52 AM
Counselor828
Aug 22, 2011 12:19 PM
schnellcgw
Jul 29, 2011 09:33 AM
kmellott
Feb 22, 2009 05:01 PM
99VolvoV70
Aug 3, 2007 10:06 AM
