Tracs...where to get?
Old Jul 11, 2006 | 11:47 PM
cool_kyle_3000's Avatar
Default Tracs...where to get?
i was wondering where i could get the tracs option for my 1996 to increase traction? cost? Also how hard to hook up?
Old Jul 12, 2006 | 12:23 AM
Default RE: Tracs...where to get?
Not sure what it consists of as an addon.
Old Jul 12, 2006 | 11:12 PM
m1964's Avatar
You'l need new ABS unit (pump+computer module) and possibly new tranny.
Old Jul 13, 2006 | 12:45 AM
Switch in Dash,Maybe the Trans. Computer as well.
Old Jul 14, 2006 | 03:11 PM
code33's Avatar
I think it's more trouble than it's worth. It's only good up to 25mph. Mine is off 99% of the time. I'm not a big fan of automatic traction control. To me, Traction Control is knowing the capabilities of your car and proper usage of the right foot.
Old Jul 16, 2006 | 03:42 PM
reg's Avatar
reg
TRACS is more than traction control.............it also incorporated skid control that operates above 25 MPH.
R.
Old Jul 17, 2006 | 03:06 PM
code33's Avatar
http://new.volvocars.com/ownersdocs/..._106.htm#pg1.9
A - TRAction Control System (TRACS) - option
TRACS is a system designed as an aid when starting/driving off if one of the drive wheels has poor traction due to weather conditions or the road surface and is connected to the ABS control module.
TRACS engages automatically at sppeds below 25 mph (40km/h) when on of the drive wheels loses traction. It disengages automatically when speed exceeds 25 mph (40 km/h). The sound which can be heard when the system is operating comes from the ABS syste.
TRACS can be disengaged manually using the switch on the dashboard. The indicator light will come on.
http://www.volvospeed.com/vs_forum/l...php/t9683.html
Old Jul 18, 2006 | 08:12 PM
reg's Avatar
reg
Well, I certainly do not want to disagree with you...............but.................on a 2002 c70 it does as I stated in my earlier post.
R.
Old Jul 19, 2006 | 01:16 AM
code33's Avatar
This is the 850 Forum and the car in discussion is a '96 850.
I believe on your car, it is called STC (Stability and Traction Control). He asked about TRACS and not about installing the newer STC into an older vehicle.
Old Jul 19, 2006 | 03:57 AM
its more trouble than worth ill just save $$$$ for S70 AWD
paulh
Jan 30, 2008 08:22 PM
rpm48
Mar 17, 2006 08:50 PM
floryed
Nov 28, 2005 09:01 PM
vwown3d
Aug 20, 2005 03:01 PM
mattad
Aug 31, 2004 11:52 AM
