trannie issues
Old Jul 1, 2005 | 04:38 PM
knight rider's Avatar
Default trannie issues
Today on the highway, I couldn't get 4th gear. It was in drive but acted as if it was in the 3 position. downshifted funny too. Did this for about 30-45 then I finally accelled up to like 80-90 and it shifted right at redline. I have driven a few places and cut on and off and it seems to be fine now. Any ideas what's goin on? I am planning on taking her down to Atlanta next week and don't want her to die on the way
Old Jul 1, 2005 | 06:50 PM
Default RE: trannie issues
Any codes at all?
When you had all the problems before did you happen to replace the TPS.
Old Jul 1, 2005 | 06:53 PM
no, I didn't change the tps. I really think it has something to do with the shift comp. It seems to be in the 3 while in drive. If I shift b/t the two it stays the same doesn't change. It is working now, but i don't want it to go out on my way to Atl. I am going to drive it again to see, but which number and port do i check for the trannie codes. No shift light though.
Old Jul 1, 2005 | 06:55 PM
A/1 is the transmission.
If the TPS is bad the trans won't shift properly.The TPS helps tell the trans when to shift.
Old Jul 1, 2005 | 06:57 PM
Everything seems to be normal other than fourth shifting to high. I will check the codes. any chance of a linkage problem in the shifter?
Old Jul 1, 2005 | 07:00 PM
1-4-3 in A1
Old Jul 1, 2005 | 07:08 PM
A-1 143= Kick down switch faulty or short circuit to ground
Which I think might be the throttle position sensor.
Old Jul 1, 2005 | 07:12 PM
Actually, i had a problem with this a while back. It is a module attached to the firewall and has the throttle cable that comes through it. It came disconnected from the firewall. I unplugged the electrical connection when I was having throttle issues. I am pretty sure that I plugged it back in, but I will check. If not, could I unplug it again and see if it works better without it?
Old Jul 1, 2005 | 07:57 PM
Unplugged the kick down switch connection and it is still driving fine
Old Jul 1, 2005 | 09:47 PM
Clear the code and see if it comes back.
Old Jul 6, 2005 | 01:49 AM
swede850T's Avatar
Has this problem come back -- or did that fix it?
Old Jul 6, 2005 | 01:58 PM
Just got back from a 3 hour trip and it has been a couple of days with no problem. I don't know if unplugging the kick down switch connection helped b/c the problem stopped before I did this. I think it was just a fluke in the system but we will see.
I am Phil
Dec 10, 2011 10:23 PM
