trans fluid flush
Old Sep 24, 2010 | 12:21 PM
tater's Avatar
Default trans fluid flush
I'm going to flush my trans fluid since it looks like mud. Which would be better to use? Amsoil, royal purple, or mobil 1.
Old Sep 25, 2010 | 02:40 PM
boxpin's Avatar
Mobil 1 got recalled for some reason..look into that before going that route.
Some say Lucas Oil is the best. I think you will find all different opinions. I just flushed mine yesterday with Valvoline Synth.
Old Sep 26, 2010 | 02:59 PM
NCdad's Avatar
Default Trans flush --- or Drain and fill
After reading and hearing some horror stories about 850's not running right after the transmission fluid was changed, I did a lot of searching and reading on this website before I changed mine. It turned out that this seemed to occur when the transmissions were 'flushed' instead of the "drain and fill" method.
My Volvo dealer mechanic told me not to change the fluid at all unless it was burnt. I could not stand not changing the trans fluid, after all my transmission does not have a filter!
I finally made up my mind to do the 'drain and fill' method --three times. It worked like a charm ! I used SUPERTECH Dextron III from Wal-Mart. It costs about $ 12.00.
I recommend you perform a search and read the thread How to change tranny fluid from 4/17/2009.
patrm
2001-2013 model year V70
23
Mar 5, 2014 08:43 PM
urdrwho
Nov 14, 2013 07:12 AM
shop2
Nov 1, 2011 08:56 AM
Glenn B
Feb 19, 2008 04:57 PM
cesupro
May 8, 2007 12:22 AM
