Transmission Banging
Old Dec 7, 2007 | 12:38 PM
waves's Avatar
Default Transmission Banging
I just took my 850 turbo to volvo fort washington to get the gear selector switch replaced and now volvo saying my transmission isbanging into the next gears but when i drove it to them it was shifting fine they said the computer said it had a gear ratio error or something, has this ever happen to anyone out there how can a tranmission go from shifting fine to banginggears
Old Dec 7, 2007 | 06:17 PM
Default RE: Transmission Banging
I have never seen that in my time.
Not to say it can't happen.
Old Dec 8, 2007 | 06:29 AM
JPN's Avatar
JPN
I wouldn't go back to the dealer. The code for "Incorrect Gear Ratio" appears on something trivial as well. Mine once triggered it by low fluid, as little as a half quart. The car went into limp mode and the shift arrow on the instrument panel kept flashing. I took it to an AutoZone, and they read the code with Actron CP9175 OBD-II scanner. I had the code, and I knew I was a bit low on fluid, as I had serviced a CV joint previously and when I disconnected the drive shaft, I had lost about a half quart of tranny fluid. After being topped up, the code never returned.
Is your car still shifting fine? If so, forget the dealer. If you noticed a problem, the dealer should fix it at no charge.
If your 850 is of '93-'95 model, you can retrieve the code by yourself. Let me know if you want to retrieve the code & reset the computer. If it is of '96/'97, visit a local auto parts shop such as AutoZone and have it diagnosed via OBD-II and have them reset the code. The code should turn the check engine light, though.
JPN
kelsodatrini
Nov 18, 2010 04:15 PM
wendib2
Jul 18, 2009 05:30 PM
eyukins
Nov 25, 2007 02:03 AM
Sunsetblues66
Nov 10, 2007 01:15 AM
CWVS
Nov 29, 2006 08:40 PM
