transmission QUESTION
Old Jul 14, 2008 | 11:26 PM
oscarg's Avatar
Default transmission QUESTION
hello everyone this is my first post here I have an 1995- 850 GLT andI have a bad transmission I took it to 2 different shops and they both told me the same thing replace transmission.
I bought a good used transmission suppostly for a 1995- 850GLT a couple of months ago guaranteed to work but the problem that i face now is that the speed sensorconnector is on thetop side and the original is in the bottom side please help .I almost forgot to mention that the guy at the shop told me that this used transmision is from a newer car a year or two then my but it will fit with no problem exept for the speed sensor that is in thetop not botton he said that he could cut the two cables gray and brown and add the other plug to it so it will fit but he said that there may be a software error but he is not sure about itthat that could happen once the trainy is install. THANK YOU
Old Jul 15, 2008 | 06:56 AM
lister99's Avatar
Default RE: transmission QUESTION
I recall someone else had that problem here not too long ago, and that question was adressed.If you do a search you may find your answer.
mason3325
Dec 22, 2021 12:51 PM
jeffrisley
Jun 14, 2015 01:48 PM
n2umr
Dec 2, 2004 10:01 AM
