Transmission trouble code
Old Nov 11, 2007 | 09:02 AM
Quincy56's Avatar
Default Transmission trouble code
Yesterday my "arrow" started blinking. It wouldn't go off even aftershutting down and restarting.The owners manual says it is a transmission error. The transmission is shifting fine.I get home and figure out I need to look it up using the diagnostic block under the hood (A block, port 1).
I press the button once, and a 323 code which says something about "lock-up" and could be electronic or mechanical failure.
One strange thing, I couldn't get it to clear following the instructions, however the arrow is no longer flashing.
Anyone familiar with this code or clearing them?
John
Old Nov 11, 2007 | 09:56 AM
Default RE: Transmission trouble code
Sometimes it takes a few times to get it to clear.
Fluid level full?
Old Nov 11, 2007 | 10:10 AM
Quincy56's Avatar
Good question. I haven't checked the fluid yet. The PO was quite good about taking the car in every 3000 miles for an oil change (mostly to the quickie places) and I would hope that they were checking it. As far as I know, they are supposed to check all the fluids.
I'm also thinking of doing thefluid change using the coolant lines mentioned either here or on another board.
dphilips75
Oct 21, 2009 12:32 PM
Lukester
Nov 12, 2007 01:04 PM
dave_n_s
Oct 11, 2005 10:31 AM
dmoney
Jul 23, 2005 01:42 PM
kdfair65
Jul 22, 2005 09:38 PM
