tubrochargers
Old Dec 29, 2005 | 06:23 PM
kcfd's Avatar
Default tubrochargers
hi i was wondering what is the best turbo to put on a 850 R 1997 mine is leaking and i was told i needed to replace it please someone help me
Old Dec 29, 2005 | 09:21 PM
JimKW's Avatar
Default RE: tubrochargers
I would try and find a used one off of another 850 Turbo. Pretty sure they were all the same from 94-97. They should not be hard to find.
Old Dec 29, 2005 | 10:20 PM
kcfd's Avatar
thanks for the info what should one run $ and can they be rebuilt
I was told it was leaking at the main seal, can i just change the gasket
Old Dec 30, 2005 | 12:15 AM
reg's Avatar
reg
I wonder Jim if they (turbo unit) isn't the same for any of the high pressure turbos manufactured for the 2.3 liter engine??
Reg
ORIGINAL: JimKW
Old Dec 30, 2005 | 01:43 AM
robert213's Avatar
If you are led to believe that your turbo has a problem...
Does your engine use more than 1/2 quart of oil per thousand miles?
Remove the turbo inlet hose between air filter box and turbo. Do you see oil puddled inside of turbo housing? Firmly pull on turbo compressor wheel. Is there a lot of slop and play in the turbo shaft?
Have your current turbo rebuilt professionally. It shouldn't cost much more than $300. Remember to use a new turbo oil feed line. Shop and Compare, starting with Forced Performance...
Volvo owners have been recommending...
http://www.dallasturbo.com/
Majestic Turbochargers of Dallas
1000 S. Wildwood
Suite 10
Irving, TX, 75060
http://www.hirschinds.com/
HIRSCH FOREIGN
P.O. BOX 18063
PHOENIX, AZ 85009
Mitsubishi owners use...
http://www.turbochargers.com
Turbochargers.com
5410 Burr Oak Drive
Houston, Texas 77092
Tech Line: (713) 681-1111
Order Line Toll Free: (800) 749-7111
Fax: (713) 939-1111
Email - Turbo@turbochargers.com
http://www.forcedperformance.net/
Forced Performance
671 New Hope Road West
McKinney, TX 75071
Phone: (972) 984-1800
Fax: (972) 984-1802
Sales@forcedperformance.net
Rebuild@forcedperformance.net
Old Dec 31, 2005 | 04:48 PM
kcfd's Avatar
thanks for the info
i pulled the oil dip stick and there was a white grease all over it any ideas
Old Dec 31, 2005 | 11:49 PM
robert213's Avatar
ORIGINAL: kcfd
thanks for the info
https://volvoforums.com/m_18765/tm.htm
Old Jan 1, 2006 | 01:44 PM
kcfd's Avatar
Thanks
I was also wondering if it is hard on the engine or if it is going to damage anything else further if i drive the car with a bad turbo
